Go back to regular Oil
I looked on line for some explanations and found there is support for both the "Yay" and the "Nay".
Check these out: http://wiki.answers.com/Q/Is_it_harm...with_synthetic
http://www.mobiloil.com/USA-English/...entionals.aspx
Did you know that anyone can add or edit information on WiKi? No qualifications or factual knowledge is required.
In this case, the forum is a far more reliable source if you look at what the old timers are telling you.
As said above: Fact - Your bike came with dino oil in it and when it was changed to synthetic, almost a quart of the dino was left in the system. It happens every time you change your oil.
Well then I guess I'm an old fart at the age of 34..........Got my first scoot at the age of five or so, and my dad, older brother & I ripped it down that winter for tweakin & painting. Been working, (aka..learning from dad), on stuff ever since. My dad was a Navy jet mechanic way back when.
I do the same thing (change oil and filter every 2,500 to 3,000 miles) no matter what type of oil I happen to be running....
Maybe some would consider that 'overkill', but I've followed the same routine for well over 35 years and old habits are hard to break...
3 quarts of oil and a new filter aren't that expensive, and I just like running fresh oil..
