Fork tube extensions
Old 12-25-2008, 02:28 AM
marksfatboy's Avatar
marksfatboy
marksfatboy is offline
Default Fork tube extensions
Anyone use these? Would this be a cheaper, easier solution to extended fork tubes? Thanks Mark
http://www.billski182.com/Sportster_Fork_Extensions.htm
Old 12-25-2008, 02:34 AM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
The Price Looks right anyway... Although never tried them perhaps someone who has will chime in ...
Old 12-25-2008, 09:52 AM
Zimbob's Avatar
Zimbob
Zimbob is offline
Seems to me that holding a fork tube with two points would be safer and take a greater side and forward loading than a fork tube that's only clamped in one place. I wouldn't trust it myself.
Old 12-25-2008, 01:03 PM
Lindsey141's Avatar
Lindsey141
Lindsey141 is offline
These were a little more common 20, 30 40 years ago. I have not seen then used much in quite awhile.
Definately a easier way to extend the forks but I think you would be sacrificing some of the strength of one solid down tube.
Also there will be a visible line where it joins with the down tube which (when looking closely) will not look good.
Old 12-25-2008, 01:11 PM
WRAITH's Avatar
WRAITH
WRAITH is offline
First question to ask, are they DOT. approved? Second, do they meet your local state laws?
Old 12-25-2008, 04:31 PM
Mark g's Avatar
Mark g
Mark g is offline
I would just buy longer upper tubes. That's what I did to my nightster.
Old 12-25-2008, 06:24 PM
pococj's Avatar
pococj
pococj is offline
Received 1,297 Likes on 484 Posts
Used to be known as "slugs". As long as the joint is between the upper & lower triple clamps, it is s'posed to be safe. But I saw a few that broke. It ain't pretty, especially when the joint is below the lower tree.
Old 12-25-2008, 07:37 PM
marksfatboy
Hey Mark G. What length did you go with? Thanks Mark
Old 12-25-2008, 09:01 PM
Mark g's Avatar
Mark g
Mark g is offline
I bought stock tubes & dampening tubes from a custom. 2" more travel.
it really set the bike off, The ride improvement was a + too.
Old 06-10-2011, 01:00 PM
dguyer's Avatar
dguyer
dguyer is offline
Stage IV
Default Fork Extensions
Trike Your Bike has been using an extension on their kits for a couple years now without any problems. They suggest raking the front when you convert the bike to a trike. Raking the front 5 degrees requires a 4" extension to get the bike to ride at the same height as it did stock. I recently converted my wife's 1200 Nightster to a trike and added a 5 degree trees and a 100mm extension to the forks. It now rides better than without the extensions. I used the extension listed in the link below.
http://www.bikercom.com/shop/index.p...&ref=GZ-316119
Hope this helps.
Quick Reply: Fork tube extensions
