what does XL stand for?
Old 12-10-2008, 09:04 PM
sbergloff's Avatar
sbergloff
sbergloff is offline
Originally Posted by Boo67
Nice looking Nightster you have
Thanks.
Old 12-10-2008, 09:37 PM
7/11 The Crapshooter's Avatar
7/11 The Crapshooter is offline
Originally Posted by OldFenderGuy
If I'm not mistaken, the XL in 1957 only had a compression ratio of 7.5:1.
In 1958 they introduced the XLC (Competition) and XLCH (California Hot) models which had higher compression, bigger valves, domed pistons, etc......
Even so these higher performance XLC and XLCH models weren't 'speed demons' and published articles showed quearter mile times in the 14.5 to 15.0 second range.
The Original 1957 Sportster had 53.9CU. IN., (883cc), 3.0" x 3.81" bore/stroke, 7.5:1 compression, 40hp @ 5,500rpm. 14.5 to 15.0 was fast at that time and I believe there were less than 2,000 units built that opening year. In 1958, things took a real jump for the Sportster as it stayed at 53.9 CU.IN.(883cc), 3.0" x 3.81" bore/stroke however, the heads were changed giving it 9:1 compression, 45hp, a triplex primary chain and it would top out at an impressive 115mph on a bike that weighed 480 lbs. This was the XLCH or Competition Hot as some would call it although I can not confirm Harley ever used the term "hot." Most would say Harley used High power although it was later used for the huger.
Old 12-11-2008, 01:45 AM
2003Sport's Avatar
2003Sport
2003Sport is offline
Xtra Long
Old 12-11-2008, 02:47 AM
otaramc's Avatar
otaramc
otaramc is offline
XL -Xtra Little
Old 12-11-2008, 09:06 AM
Skygoose's Avatar
Skygoose
Skygoose is offline
It's actually 7X. You're reading it upside down. Like the 710 cap on yer tank.
Old 12-11-2008, 03:16 PM
Shadow_Demon's Avatar
Shadow_Demon
Shadow_Demon is offline
I agree withe the Xtra Large.
Old 12-12-2008, 08:45 AM
mississippiboy's Avatar
mississippiboy
mississippiboy is offline
FYI the January addition of AIM magazine gives you a detailed defention of all the symbols. Giving its 3 pages long and confusing as hell but well worth the read!!
Old 12-12-2008, 12:32 PM
Shadow_Demon
Xtra lean and Mean
Old 12-12-2008, 07:46 PM
vet767's Avatar
vet767
vet767 is offline
Old 12-12-2008, 08:18 PM
Mike5959's Avatar
Mike5959
Mike5959 is offline
http://factoryfat.com/hdbikemodels.html
The first letter of the model designator reveals the engine series:
First character:
G - Servicar three wheeler, 1937 to 1972
E - Overhead valve 61 cubic inch "big twin" (Engine/trans separated)
F - Overhead valve 74,80 or 88 cubic inch "big twin"
FL - 80 to 88 cubic inches and a fat front tire. (Also 74" 1941-82)
K - Side valve 45 and 55 cubic inch sports bike that replaced the WL in
1953 and was replaced by the Sportster in 1957. It had many design
features that were carried over to the Sportster.
U - Side valve 74 or 80 cubic inch "big twin"
V - Side valve 74 cubic inch 1930-36. (Also 1935-36 VLH, VHS 80)
W - Side valve 45 cubic inch made 1937 to 1952
X - Sports and special construction. Applied to 1918-1922 opposed twin
Sport, 1944 military opposed twin, and 1957 to present Sportster.
The second letter of the model designator reveals the Front end (except sportsters):
X - Narrow tire and sport forks.
L - Wide front tire and Hydra-Glide front forks.
The third letter of the model designator reveals the frame style:
D - "Dyna" frame (with the rubber mounted motor)
HT - "Highway Touring" frame
ST - "Softail" frame
The next letter(s) indicates the model bike within the frame family:
A - Military (Army) version (except GA, Servicar without tow bar)
B - Battery start (early models), Belt drive (early 80's) Black paint.(1995-6 model, the Bad Boy)
C - Classic, Competition, Custom, various others meanings.
D - Dyna, the newest frame and engine mount design.
DG - Disc Glide
E - Electric start
F - Foot shift (when the standard was hand-shift) and now "Fat Boy®"
H - varied between High performance, hand shift and Heavy duty.
I - Signifies Fuel Injection.
L - Big fat front tire
LR- Low Rider (though many Low Riders don't include LR in the model ID)
N - Nostalgia
P - Police version
R - Rubber mounted engine (some models) racing version (other models)
ST- Soft Tail
S - Springer
S - (without following T) Sports version
T - Touring
WG - Wide Glide
X - Sportster or sportster-type front end and Skinny front tire.
Quick Reply: what does XL stand for?
