Breather Back plate
Old 12-08-2008 | 09:01 AM
WildBill_50's Avatar
WildBill_50
Default Breather Back plate
When I bought my Sporty it came with an extra Breather back plate in this photo
My bike currently has this installed.
My question is which is better for performance. The guy who owned the bike said he installed the first plate and the bike didn't seem to run as well so he put it back to current configuration.
I also want to install a K&N Air cleaner so is there any other considerations like jetting?
Thanks
Bill
Old 12-08-2008 | 10:09 AM
SportyPig's Avatar
SportyPig
The one that is not installed is the stock backplate in it's original condition. The backplate that is shown installed is the same backplate with a majority of it cut off. They both appear to have the same part number.
Since the bike has a modified backplate, I suspect the carb has already be re-jetted. Unless you can find out the history here, they only way you can tell is to remove the jets. They have a small number stamped on the bottom that indicates the jet size.
Also you didn't mention anything about the exhaust. From your signiture picture, the pipes don't look stock. That further makes me believe the carb has already been re-jetted.
Old 12-08-2008 | 06:34 PM
WildBill_50
Thanks Sporty, I wasn't sure which would be the best for performance. Most all of the custom work was done by the original owner, I'm the 3rd owner. The pipes are BG so I guess they probably did rejet. I never noticed the shape of the original AC back plate so.
Thanks for the info.
Bill
Old 12-08-2008 | 07:04 PM
RATROD HOG's Avatar
RATROD HOG
it is a clean looking job (backplate)
should be 2 O-rings on the breather bolts thats what seals it up.
should aleast check that
and your bike looks nice there
timsmcm
EVO
13
04-03-2020 05:34 PM
Tactical111
03-29-2013 10:06 PM
streetfighter06
02-18-2011 08:40 AM
hawkdsl
Exhaust System Topics
04-11-2010 11:48 PM
tpb857
10-06-2009 10:56 AM
Quick Reply: Breather Back plate
