Lift/stand
can see the oil level on the clutch when you refill it. Thing is, the secret
that no one has told you yet is that, it's waaay easier to just fill through
the chain inspection cover and put in exactly 28 ounces of fluid. Do that
and the level will be correct. If you want to continue to do the derby
cover method, then don't take it off until you are finished draining and
have replaced the drain plug, then have someone sit on the bike and hold
it vertical while you are refilling it.
The 28 ounces is for a solid mount evo, not sure if it's the same on a rubber
mount, someone might want to chime in and cover me there.
Have a happy day,
Gazza
You read the manual right, it tells you to remove the derby cover so you
Have a happy day,
Gazza
Have a happy day,
Gazza
rdondes
03-17-2010 01:43 PM
