cracked crank case
cracked crank case
put my nightster in for its 1000 mile service today it done 930 miles got a phone back saying the crank case was cracked anyone had this problem
its a good thing for warranty
i heard the cause of this is bad balancing in the motor is that true
when they are reved to hard they crack buts whats the piont if you cant rev them its got 46 horse you would never get any where
is this likley to happen again
or should i just sell the piece of shyt before the warranty runs out and buy a proper bike like a ktm superduke
god dam harleys to good to be good
dont mean to rant but i was starting to like harleys getting over the dont turn dont go dont brake
a cracked case is def messed up, sounds like a flaw in the casting to me but a bad crank balance could cause it too ?, it is nice that warrantee will replace it for ya....been around bikes for a long time and that is very rare...i cannot ever remember hearing about that on a sporty case before.
them saying you cannot rev it is bull****, a shop up the street from me has a turbo'd sporty on their showroom floor and it revs like mad, hell i redline mine quite often.
after all it is a man made electrical and mechanical machine, ****s bound to break at some point, thats a guarentee.......even metric bikes break !
Received 1,296 Likes
Glad the warranty will cover it. Doesn't seem to be a common problem, so you'll come out OK.
"Back in the day" it seemed every Ironhead I took down had cracks in the cases. Most were minor and a good cleaning and a good welder fixed 'em up. When I had my first '72 CH rebuilt while I was overseas, the cases had 14 cracks. None critical & all fixed by Duck, RIP.
Sporties were famous for grenading the tranny trapdoor, and for blowing the lower right rear corner of the tranny case out. There was even a heavy duty casting on the market to replace that corner. Usually when the trapdoor exploded the tranny guts moving at high speed in unintended directions would often cause cracks in the cases.
Much as I don't like the new Sporties not having that trapdoor, it's a stronger motor without it. Even HD gets some things right!
Let's go back a second here. Concerning the last few posts', HD does "NOT" balance any Big Twin cranks anymore, so that will not crack a crankcase. I have built Sporster Performance Flattrackers for years and have had crank issues, never cracked a case. The Iron Sporty's would blast the trap door out of them, but the trap door was cast from soda can aluminum. If you built any power into the motor the trap door could not withstand the constant side loads and fail. The sprocket shaft inserts would also come loose and crack the case inside the primary behind the engine sprocket. Iron's and 4-speed XL's had that issue. Yours does not have that trap door.
You need to ask a few more questions. Did your bike have any oil leaks? The weakest areas of any XL case is in the cam chest near the pinion bearing and the sprocket shaft insert. Where is the case cracked? I have not seen cracked crancases in years. If it is, I would think it would be a casting issue. Get some more details.
Lopoetve
05-18-2010 08:17 PM
