Questions about Seafoam??
Old 11-22-2008 | 04:55 PM
crazytrain69's Avatar
crazytrain69
Default Questions about Seafoam??
I'm getting ready to add some Sea foam to my fuel. I think the correct amount would be 1 ounce per gallon of fuel. I was also wondering if i should add a little to the oil as well?? If so How much should i add to the oil?? i didn't see any amount for that. I have a 2008 1200c getting ready to park it for the winter until we have some good days i can take it out for an hour for a spin. By they way it sounds this is some good stuff!!!! I sure hope so!
Old 11-22-2008 | 04:59 PM
cHarley's Avatar
cHarley
No, do not put it in the oil. That is only done sometimes to help clean out sludge and moisture, and then it's done just prior to doing an oil change. 1 oz per gallon is correct for adding it to the fuel.
Old 11-22-2008 | 05:06 PM
crazytrain69
thanks cHarley I will not add any to the oil! I'll only add it to the gas. thanks for that bit of info. I did Know that about the oil change. I just wasn't thinking for a second.
Old 11-22-2008 | 05:32 PM
xxxflhrci's Avatar
xxxflhrci
If you are looking for a fuel stabilizer, IMO, Stabil is better for the job. It is designed just to stabilize fuel, not do a whole list of miracles like Seafoam advertises in the propaganda on the can that it does.
If you are not laying it up for months at a time and can take it out for an hour spin every now and then, you do not need to add anything to the fuel.
Old 11-22-2008 | 05:40 PM
2005UltraNC's Avatar
2005UltraNC
Would not use it as a fuel stabilzer. I use it to clean out the injectors, etc. Also, I would never think of putting it in the oil.
RATROD HOG's Avatar
RATROD HOG
+1 on stabil for gas
Old 11-22-2008 | 06:02 PM
crazytrain69
Thanks for the info.
Old 11-23-2008 | 09:46 AM
iowafarmboy's Avatar
iowafarmboy
6th Gear
I did put some (maybe 4 to 8 oz's) in the oil. I drove it for two miles and now it's in storage for 6 months. I'll change the oil and filter before I ride it again next year. Is there a brand of oil (for next year) that is better than others.? How about synthetic oil or synthetic blends.
Old 11-23-2008 | 10:17 AM
Terp84Alum's Avatar
Terp84Alum
I run SeaFoam in all my toys. I was also told that it is not a great stabilizer. Use Stabil. Ride/Store safe
Tryker Dude
23
02-10-2019 09:20 PM
Kisse87
03-31-2010 07:04 AM
lovemydeluxe
Oil Archive (no new posts)
04-20-2009 10:19 PM
WARG
Exhaust System Topics
08-01-2008 08:54 PM
WARG
02-27-2008 03:19 AM
Quick Reply: Questions about Seafoam??
