Internal wiring....
Old 11-17-2008 | 09:55 PM
motordrum's Avatar
motordrum
Default Internal wiring....
I am wanting to run my wires internally on my biltwell frisco bars on my Nightster. How would I go about it? Where do I disconnect? This may be a dumb question, but I don't usually like messing with wires but I am wanting to do this myself.
Thanks
Old 11-17-2008 | 10:19 PM
aceospades's Avatar
aceospades
the disconect should be under the tank atleast it was on mine,when i did my bars i ran the wires internal and had to re-splice all of the deutsch connectors..its not all that bad,just take your time
Old 11-17-2008 | 10:22 PM
jtaylor's Avatar
jtaylor
motordrum,I think it would be easier if you were to cut the wires run them thru the inside of your bars and out the bottom then solder them back together and use shrink wrap on each wire.
If you were to disconnect were they plug into the plug under the gas tank I think the plugs are to big to go thru the holes in the handle bars.I am going to run the wires thru my drag bars I am putting on my Nightster.
Old 11-17-2008 | 10:30 PM
aceospades's Avatar
aceospades
if you unplug from the harness under the tank you can cut them there and get the new pin(deutshe) connectors to replace the ones you cut off at your local stealer..if you need to extend the wires i think you can get a harness from the dealer to extend the existing wires
Old 11-17-2008 | 10:31 PM
dlg1125's Avatar
dlg1125
I just completed this a few hours ago, there are several steps but if you take it one at a time it is easy.
1) remove controls and grips from stock bars, along with attached wire harness.
2) remove the connectors from the wire harness (the end that connects to the bikes main wire harness) this can be tricky. Looking at the connectors at the end where the wires go into the connector there are 2 holes between all of the wires, use needle nose pliers to pull the plastic piece out a little, it will snap out about 1/4 inch but will stay in the connector body. Then look at the other end of the connector (where the pins come out) above each pin is a small hole, use a push pin about the size of a paper clip and insert into the hole until it clicks, you can then pull that wire out, repeat until they are all out. Remember to draw a diagram so you put them back in the correct order.
3) measure how much more length you need by mocking up bars and measuring with spare wire/string etc.
4) Now you need to extend your wires by cutting and soldering in extensions, make sure to stager your joints to avoid a lump of connections and to heat shrink all connections and then heat shrink the entire harness again to avoid chaffing.
5) if your bars aren't pre-drilled drill the needed holes.
6) Thread fishing line or light string though your bars, then attach to heavier string and pull through, then use electrical tape and join the string and your new harness and pull through the bars.
7) Insert wires into connectors using your previous diagram, then snap the plate on the reverse side back down to lock in the wires.
8) Mount controls on bars, bars on bike, plug in wires and RIDE!!!
Hope this helps, let me know if Im not making sense any where.
David
Old 11-17-2008 | 10:45 PM
jtaylor's Avatar
jtaylor
David
dlg If you were to remove pins from connector then if you had enough wire length you could proble just run wires with pins thru bars and then put pins back into connector right !
JT.
Old 11-18-2008 | 07:19 AM
dlg1125's Avatar
dlg1125
JT.
Ya, you could, I just didn't know if he needed to extend his wires with those bars, so I just included the necessary steps just in case.
Im glad someone could understand my rambling on!
David
Old 12-22-2008 | 08:00 PM
GONZEE's Avatar
GONZEE
thank you tis will help
toku58
08-04-2013 05:34 PM
T-rat
04-10-2013 11:54 AM
GeneBinderFXDB
03-04-2013 11:26 AM
thexman10
03-10-2009 10:50 PM
GPHDXLC
12-26-2008 01:56 PM
