Lowered front fender
Old 11-17-2008 | 12:42 PM
BLKXL12C's Avatar
BLKXL12C
OK we can all drill holes but how did you get the bend at the bottom of the bracket?
Old 11-17-2008 | 01:07 PM
mississippiboy's Avatar
mississippiboy
damn nice
Old 11-17-2008 | 02:24 PM
Willie D's Avatar
Willie D
Unhappy Fender
Originally Posted by alank
Here's a shot of my lowered front fender. I've never liked the looks of the highwater front fenders on the Sportsters & Dyna's.
I like it too, but HOW did you accomplish it ?
WD
Old 11-17-2008 | 03:22 PM
JRK5892's Avatar
JRK5892
looks great! have you guys taken into consideration the tire expansion? should have about 1/4 in of play there... looks great!
Old 11-17-2008 | 03:39 PM
venable's Avatar
venable
That does look real nice.
Old 11-17-2008 | 03:45 PM
Yatez004's Avatar
Yatez004
Ive brought mine right up to 100mph and it dont rub! We used an extension cord for a spacer between the wheel & fender, heres some pictures of how i did mine, the right way, to make my bracket one piece with the fender! I have over 200+ pictures of the work i did last winter
Old 11-17-2008 | 04:13 PM
Willie D's Avatar
Willie D
Red face Fender
Looks like too much work for a guy that only has a hammer and hack saw ! LOL
but I do like the finshed product........how much would it cost to have it done ?
WD'
Old 11-17-2008 | 04:16 PM
Yatez004's Avatar
Yatez004
It would cost quite a bit. The way i did it, there was alot of work involved but the finished product was well worth it
Old 11-17-2008 | 05:16 PM
alank's Avatar
alank
Unhappy
Well, Yatez004 has all the pictures of basically what I did, except I just cut the entire top of the brace out and removed it, then welded the remaining side braces to the fender. That way there is nothing inside the fender to interfere with how close to the tire you want to mount the fender. The picture shows the amount I removed in the lowering process. The other thing you have to do is re-curve the fender. The diameter the fender is designed to be larger than the 19" or 21" tire. When you set the fender on the tire, the center of the fender rests on the tire and the ends of the fender stand out away from the tire, so it needs to be re-curved so the clearance will be uniform all the way around. This is done by slightly widening the fender. As you widen the fender, the diameter will get smaller, and as you squeeze the sides of the fender together, the diameter will increase. Just keep working it until you get the diameter just right for the way you want to mount it. It isn't that big a project, but a hammer & wrench won't do it either.
Old 11-17-2008 | 07:43 PM
RATROD HOG's Avatar
RATROD HOG
Well dam least i still got a good eye for whacked out zhit.
never easy is it.
Well Thanks for letting us poor bastard know.
Many Thanks
Quick Reply: Lowered front fender
