HD warranty?
No!!!
You have to get equivalent service work done but it can be done at any
indie shop or in your garage as long as you save the receipts that show you
did the oil changes,and if you do it yourself it might help to have a receipt
for a service manual.
The HD warranty is the biggest scam in the world, and most dealers use
scare tactics to help the scam along. It's a scam because they pressure into
paying the ridiculous rates for HD service... but it is illegal to void your
warranty because you had work done at another shop or did it yourself.
Best thing for you to do is let your warranty expire (please say you didn't
buy the extended warranty) and buy your self the factory service manual. It
explains how to do all of the scheduled srevice work and you do not need a
boat load of specialized tools to do that work, just a good socket set and
some torx and hex head drivers.
That said you should get the 1K service done at your dealer just so you
know what you're saving later on when you start doing the smart thing. ANd
remember that a 5K service costs about twice as much as a 1K and a 10K
costs about twice as much as a 5K service.
Gazza
Gazza
Does it have to be done by the dealer? - NO, but you need to document the work, date, mileage, etc. and keep dated receipts for the parts/materials used. If the dealer tries to say otherwise, mention the Magneson-Moss Act and watch him squirm.
I do however recommend that the dealer do the 1K service, they are signing off that everything from the factory is up to snuff. After that DIY if you are able.
By that kind of logic, then you should have all of your service done by the dealer.
Forget what the dealer is trying to scare you with. Do it yourself so you will know it gets done or take it to a reputable indy shop or the dealer and hope it gets done. I'd bet a lot of 1k services amount to roll 'em in change, change the fluids, hold the bike hostage a few hours, and then charge the customers big bucks.
I don't doubt that many dealers skip all the checks required at the 1K service, but they are signing off that they did so and are thus liable if any related problems arise.
But, to each his own......
