what jet sizes r u running on?
RE: what jet sizes r u running on?
I too have drag pipes on a 2006 883. I installed the 45 slow jet but honestly it can stand to go to a 48. As for the fast jet the bike already had a 175 from the Motor Company and it was still too lean...Harley Shop was closed by the time I discovered this so I just ended up drilling it out to what amounts to a 195 and its running perfectly...hope this helps.
Do you have the extra stuff from the T-slide kit? T-slide kit destructions say to use 185 main if you have aftermarket airbox and/or exhaust. I'd start there. Shouldn't need more than that unless you change cams or do head work.
Also says to run with the stock 42 initially and go up if you need more then 3.5 turns on the mixture. I went up to a 45 on both my bikes. 48 is too much, even with drags.
Here's what I'm running...
Bike 1: 06 1200C Sport Bob
SE AC
CS Slip-ons
T-Slide kit
45/185 jets
Bike 2: 06 1200L
SE AC
Stock mufflers
DJ kit (3rd slot on the needle and all 3 shims)
45/180
SE AC
CS Slip-ons
T-Slide kit
45/185 jets
Bike 2: 06 1200L
SE AC
Stock mufflers
45/180
I started with the 45 to be on the conservative side and find that the idle mixture adjustment screw is out quite a bit, which is why I think it could stand a 48. Im right at sea level around here and that 175 main was just too lean with the drag pipes. Im happy with the surgery I did on that main jet and its not fouling so...but then again every bike is different so starting out with recommended sets from the manufacturer of the jet-kit is a good place to start.
I'd recommend coming up one size on the slow jet for starters. Every bike is different and not sure how different your drags are to my mufflers but maybe try a 45/185 like I am running. I've got so much low end pull I had to reset the handlebars and over torque the riser bolts. I pulled the bars back trying to hold on when I opened up the throttle.
2005 883C near Phoenix, AZ (altitude approx. 1100')
Cycle Shack turnout slipons (about $180 from Heritage Cycle Works)
S&S air cleaner (about $170 from Sorgys)
45 pilot jet (about $5 bucks from the stealer, including tax :-)
175 main jet (stock)
drilled out plug and 2.75 turns out on the idle mixture screw
didn't drill the slide hole
didn't shim the needle
fart free and runs great!
Parts for Stage 1: around $355 total
Sound and Fury: priceless
ok i have V&H straightshots HS SE air cleaner the jet kit i got from HD the destructions said use 170 main and leave the slo jet alone , although i dont think it even came with a slo jet. runs pretty good but think it could have a little better response.
ecaldwell78
08-28-2008 09:14 AM
