Sound System
If you're asking me........Cycle Sounds on the internet. Installing the amplifier was easy, it's the wiring that was time consuming. First we attached to battery w/o ground (bad idea - blew a fuse). Then decided to run wiring up left side of frame and run a wire to battery and ground. Radio (or whatever you want to use) comes on with ignition switch.
It was an all-day project.
Oh, forgot to mention I ordered the incorrect system w/mounting bracket for radio. Had to order correct 'plate' for XM radio. Cycle Sound customer service excellent.
Tn.Heritage
04-22-2012 07:51 AM
