Alternative choke control?
My xl came with excellent controls and ergos with the exception of the choke control. The bike cranks quickly and smooths out in seconds--ready to ride off. Then the contortions begin: pull clutch in with left hand, reach across-over-down with right hand to push in choke, engage first gear, reach across-over-down with right hand to adjust choke, and ride away. Yes, you can just grind into first gear or wait ten minutes for the motor to warm up. But, I don't want to take either of those options. Does anyone make a right side choke control?
This is how I used my choke when I had my Sportster.
1. Pull the choke all the way out, start the bike.
2. Return the choke half way after 2 miles, it also depends on how cold the weather is.
3. Ride my bike until the rear rocker cover gets warm, push the choke in.
You can do this while you are riding, do you still need the choke **** on the right?
I can't figure out why there should be any need to use the right hand for the choke.
Step:
1 - Pull choke full out.
2 - Start bike and use star wheel to lock the throttle at a fast idle.
3 - After about 30 seconds or so push choke in 1/2 way.
4 - Let bike run at fast idle & 1/2 choke till rear cylinder is just warm to touch.
5 - Loosen star wheel, back to normal idle and put in 1st gear.
6 - Ride 1-2 miles and then use left hand to push choke fully in. You can do this between shifts when you are not busy with the clutch.
Step:
The bike shifts easily into first gear with the choke pushed in. But, your left hand is operating the clutch. You need to pull the choke back out before riding away. That is the essence of the problem. Maybe the tranny will get smoother with more mileage, but it doesn't want to slide into first gear crisply until it gets fully warmed up. The slower the idle, the better it shifts when cold.
I've seen bikes with all sorts of choke controls. Anyone have a handlebar control or a mount on the right side of the bike?
If it's that big of a deal, just make a bracket to mount it on the right side somewhere. The cable will still work in a curve shape, but don't kink it.
Oh, and I disagree with cHarley, as well as others, on the use of the throttle lock for warm up, but it's one of those "Different Strokes for differernt folks" things. A properly adjusted choke cable tension nut works wonders. I rarely even touch the choke after pulling it out on start up, as it slowly slides back in on it's own as the engine warms up.
I've never had a problem with my choke. I don't know why you'd have to adjust choke while shifting into gears.
All I've ever done is pull the choke all the way out to start up (mine won't start otherwise unless its already warm), then as i'm driving it pulls itself back in as it warms up. Just need to adjust the lock nut correctly.
I'm a relatively new rider, only been riding since March, but I don't see a problem with the choke being where it is. Then again this is my first bike so I haven't built up habits from other bikes or anything weird like that. If it's colder I'll just start it at full choke then I push it in halfway for a few minute warm up then push it in all the way after a couple minutes on the road. Hopefully I'm not fouling out my plugs (maybe I should check) but that's the way I do it. I'd like to adjust mine to go back in automatically, that must be nice.
