oil leak
Old 10-27-2008 | 03:35 PM
bescaes's Avatar
bescaes
Stage II
Default oil leak
I have a 2001 Harley Davidson Hugger 883 ... I have an add oil leak I cant figure out ... can someone help me?
I had someone look at it and since the oil looked like it was coming from the clutch cable boot ... he said that it must have too much oil in it ... so he took the derby cover off and he said it had "way too much oil" in it and it was being forced back up the line ... but that has been fixed and it still leaks ... I have a puddle of oil right under the rubber boot that is on the clutch cable ... Anyone know what else to check ... everything looks dry and I cant figure out what to check out next.
Thanks
Brad
Selandbe@royalneighbors.org
Old 10-27-2008 | 03:55 PM
HOTLAP's Avatar
HOTLAP
If it was forcing up the line it may continue to leak for quite a while as the cable is probably drenched now.
I would give it some time and try to monitor how much it leaks, if it is just residual oil coming out it should leak less & less until it finally gets completly drained.
Old 10-28-2008 | 10:12 AM
bescaes's Avatar
bescaes
Stage II
Thanks ... but the oil is now at the right level AND the clutch cable has been replaced with a new one ... and there is still a puddle of oil.
Old 10-28-2008 | 10:27 AM
Zimbob's Avatar
Zimbob
Did you replace the "o" ring on the primary where the cable goes to the clutch?
bubdifab
11
06-04-2024 07:33 PM
twistedcherokee
10-31-2010 06:49 PM
Hotwire
06-28-2010 09:03 AM
patsfan05488
06-08-2010 10:31 AM
Curly6496m
05-07-2007 02:07 PM
Quick Reply: oil leak
