First Problem wth The Sportster...
2005... 1200
Pretty sure I got a bad crank sensor... at least thats what the codes are telling me...
When it gets to operating temp she goes to missing... don't want to rev up over idle...
Done the whole fuel system thing...
Anyway... over three years and 30k... the first problem I had with it...
POS... huh?
Sure enough... bad sensor... she be running like a spotted a$$ed ape again... ;-)
Charlie D.
POS... huh?
Charlie D.
2006 883L
The bike was purchased new in June 2006. From day 1, it had an intermittent problem. Occasionally, when it was ridden in warm weather and motor was warmed up, it would cough/fart thru the carb when trying to start up from a stop light. To keep the bike from dieing at lights, you had to keep twisting the throttle. Accelerating hard, there was a flat-spot where the bike would just limp along for quite a while before taking off.
We took the bike back to the dealer and he explained that HD sets these bikes far too lean in order to meet EPA standards. He rejetted the carb – replacing the low speed jet with a #48 jet. (Stock is a #42.) He did not drill out the plug for the mixture screw, so I know he did not adjust that.
The bike ran okay for a short time, but then the same intermittent issues started again. I installed the SE intake/breather in the spring of 2007. The bike ran fine all 2007, so I assumed installing the SE intake had solved the problem.
Fast forward to 2008, and the same intermittent cough/fart thru the carb starts again, and all the other symptoms. I took the carb apart and found no crud and no obvious problems. I put in a #45 low speed jet, drilled out the mixture plug, and set the mixture screw 2 ¾ turns out. This made no improvement and all the issues were still there.
I tore carb apart again. Replaced the needle and spring with the needle and spring from a Dynojet kit. (I did not drill out the hole in the slide.) I put the needle c-clip in the 4th slot from the top and put in 3 washers. I also replaced the breather washer that had come with the SE intake kit with a couple washers that were a little thinner. (The washers in the SE intake kit were slightly thicker than 1/8” - .137”. I replaced them with washer that were slightly thinner than 1/8”) I thought this would allow the carb to fit a little tighter in the gasket between carb and manifold, perhaps giving a better seal.
At the same time, I replaced the crank position sensor because I had heard of similar issues to mine being caused by a bad crank position sensor.
After all these changes, the bike appeared to be running absolutely flawlessly. Now the question was, did the mods to the carb solve the problem or was it a bad crank position sensor??? I ran the bike a few more days to make sure the intermittent problem is really gone. Then I put the original crank position sensor back in and ran it for a while. Sure enough, the intermittent problems returned when the bike was hot. I put the new sensor back in and it has run flawlessly all season. Conclusion – Crank Position Sensor was the culprit!
well true diagnosing is the only "right" way to find a problem but sometimes at home we don't have everything we need to do that. With that in mind, in the future if you have more than one suspicion do ONE thing at a time.......and probably start with the easiest thing first
Glad to hear it is fixed
HELP!!! 2006 Sportster xlc custom carburated--- I bought a security system from H.D. dealer on line-installed it as the directions stated-(replaced the turn signal module with new security module) set up and coded the module and installed the manual disarm code. The key fob works as designed by arming and disarming the system but the engine will not stay running. It starts then stalls and sets a ecm code p1009 incorrect password. How can I correct this?? Can it be done without going to the dealer??
HELP!! Security system problems
2006 Sportster custom--I purchased and installed a factory HD security system. I set the manual default code and matched the remote to the bike. The system will arm and disarm. The system works when it senses movement and cycles the lights as designed. The problem is the engine wont stay running. It is a start/stall condition with a ECM code of p1009(incorrcet password). Has anyone had this before. How can I repair it? Or does it have to go to the dealer to get set up. If anyone can help I would be greatful
I told him he might check the hd forums... he could probably sell a bunch more...
Go figure...
Charlie D.
Problem solved
I'm glad to say its fixed. Turns out its a normal condition for adding almost any electrical part or replacment part to the Harley bikes. So here is the "learning Procedure" for the ECM to recognize any newly added electrical components.
Check out this link, it will solve the problem without going to the dealership for service.
http://i149.photobucket.com/albums/s...yingnewTSM.jpg
Incidentally, no ECM codes were thrown when this bike was running poorly. There was nothing to indicate it could be a crank position sensor problem. I replaced in on a hunch after reading of similar problems on other boards, so obviously, other people have had similar problems.
blakeusa
07-22-2014 12:40 AM
