Sportster 1200s want info
I don't think so they have a 12 or 15 degree squish band and bump up your compression to 10:1 I believe, a little bit more than a stock 1200 head with an extra plug.
Sorry dude but you are wrong. I just looked up the pistons for a 1200s and the 1200 custom and sport use the same pistons. They do have more compression but it has to be slightly smaller combustion chamber because they also us the same head gasket, could have something to do with the cams also because Harley doesn't specify if they are talking static compression or cranking compression .
The Sport was only rated at 78HP off the show room floor and that was at the crank not at the wheel which is 22hp behind any Thunderstorm.
This article describes the heads as "high compression dual spark plug heads" and under the engine specs the piston size, bore & stroke & displacement are the same as other models. That would lead me to believe that there is something different about the heads other than the extra plug causing the jump from 9.7-1 to 10.0-1 compression ratio.
http://www.totalmotorcycle.com/photo...r1200Sport.htm
Well here is the staight scope on Lightning/1200s heads (I did some research on the subject) guess what we are both kinda right.
The old original s1 lightning and the 1200s share the same heads and the reason for the increase in compression is the chamber is 5 cc's smaller they do have a 10 degree squash band but it doesn't do anything because Buell/Harley never used the matching pistons in prduction bikes and they have the same exact valves and air flow as a stock 1200 head.
They definitly aren't Thunderstorm heads.
I thought the Ligntning was a Buell model bike and Thunderstorm is a performance head /piston mod from Buell. Maybe this article can shed some light, particularly for 2003S model. http://www.sportster.org/tech/evo-tech/heads.shtml
Mr Bentwrench
Motorcycles For Sale
04-04-2014 06:34 PM
