What makes sporters good in turns?
#31
Maybe I need to try and clarify my self.
Don't brake while in a turn. I was not suggesting that at all. What I was trying to do was suggest him to try going slow in a parking lot and lean that bike over. It is very possible to scrap the pegs at slow speeds like 5 to 10mph. I have scrapped in a parking lot. So I have found how far I can really lean the bike over. I don't yet feel that confident to lean that far while going 60mph.
Can you without touching your brakes ride in a full lock turn or go from full lock to full lock in a figure 8. I seem to think this is impossible without using the rear brake and clutch together to keep a constant steady speed. I didn't come up with these things on my own I got them from the Ride Like a Pro video.
http://www.youtube.com/watch?v=wzN4Y-C0tL8
#32
Received 21,568 Likes
#33
However, in slow riding, and that is what Bryan was talking about, applying partial rear brake while slipping the clutch and holding rpms up (maybe twice idle speed) is the accepted technique for making sharp, tight and well executed turns on a motorcycle. I am a little surprised that someone as experienced as Mandog would not know this.
Out of respect for the others on the forum, I won't quote the remainder of MD's post.
#35
The #1 reason a Sporty is considered the Bike to have for riding the Twisties is low end torque. It's actually to top heavy to handle well, and the ground clearance is adequate at best, a RK has as much ground clearance and is better balanced than a Sporty. All of that isn't or doesn't have a thing to do with why the Sporty is the bike for the twisty country or Mountain roads, it's that low end torque.
#36
well looks like mandog has gotten edumacated in the last year or so since his
opinion is exactly opposite of what it was a year ago...you know MD when there was no way in hell you could get an ultra or a king to turn with a sporty and I was a retard for suggesting that it would.
you musta learned to ride that thing over the summer.
#37
What 128auto said. I was wondering when someone would mention the short wheelbase on a Sportster. Parking lot speed turns are a lot different from twisties turns. In the twisties you countersteer...in a parking lot your steer in the direction you want to go and use your body to counterbalance the bike.
Note in those police videos their upper torso is vertical, although the bike frame itself is leaned over scraping pavement. That's counterbalancing.
Countersteering is at speeds over 10-15 mph, in which the inside handlebar is pushed in order to make the curve. This gets the bike leaned to make the curve. Also, if the body is also leaned over in the direction of the curve, the bike doesn't have to lean as far to make the curve. Steering one-handed brings this physics lesson to light pretty quickly.
Also, hard braking, or braking on a slick surface during a turn is not a good idea. But trail braking is done all the time, and it can be extremely useful. Trail braking is using the rear brake to modulate speed in a turn or curve. It should be done lightly. Using the front brake in a curve is generally a no-no. The danger of trail braking in a curve is that if the rear tire starts skidding then regains traction, a high side is likely to occur. Not a good proposition for the rider to be literally catapaulted off the bike head first into terra firma. If the bike does NOT regain traction on a trail brake skid, a lowside will occur. Still not a good proposition, especially in traffic.
Bottom line for trail braking if it is done right, it can be rewarding. Done wrong can EASILY result in a crash. This is why the MSF frowns upon braking in turns. Most normal riding doesn't require it...except in some parking lot manuevers.
Teek
Teek
#38
Teek
Teek
#39
All the advice is good (Safety Course, Twist of the wrisy). Nobody has talked about suspension settings, tire compounds, air pressure. My Sporty points down the road real well. It has compression and rebound settings front and rear, holds a line in a turn really well. I'm happy with my set up.
I read an article once that said many accidents could be avoided if riders trusted their tires to hold a turn more. Some bikes lean over easy initially and then it is hard to push them over farther. My daily driver is a tricked '00 ZRX1100 (54,000 mi), so while I am conservative, I do have a comparison.
But please, the road is not the track. You never know what's around the corner. After a rain is always dangerous because of sand and debris washed onto the road. In my case, I have encountered Brahma bulls aroud the turn on the road, been run off by a truck coming the other way, et al.
Ride safe.
Ride safe.
#40
Ride safe.
Ride safe.
