First biike, Sportster 883...Rough first gear?!
I just bought a 2006 883, with about 10k miles. It's my first bike ever, so I could be just ignorant. Especially to Hrleys. It has some aftermarket things done to it, nothing crazy. Lowered rear suspension, new risers, jetted carb, handle bars, pipes etc....
Now...when I start out in first gear, and am completely out of the clutch and accelerating, the front end seems to vibrate. Now I know it's a harley...but it just doesn't seem right. I don't think the rim is bent. It's probably nothing at all and I'm just paranoid, but like I said it's my first bike ever, so I have nothing to base it on. I bought it from a friend of mine, and I know he would have either A disclosed anything wrong with it, or B just sold it to someone else if there was a problem.
Is this normal? It's ridable! and It seems like it goes away in the higher gears, so maybe I'm just paranoid!!
Sorry to ramble...I'm just curious now. Thanks for any input. Positive and negative!
My guess is it's not a difference in gearing but the characteristics of a rubber mounting system. The engine is allowed to move slightly so that the recoil of the engine lugging makes the engine shake. In a solid mount the engine would not be able to move around without moving a much larger object, the bike itself, so the engine gains no momentum and doesn't shake noticeably more than normal.
Either that or a solid mount already shakes so much that lugging the engine is a such a relatively small increase as to not be noticeable.
One way to make sure it's not the rim is to get up to around 20 mph, then pull in the clutch and coast back down to the speed where you are feeling the vibration. If it's a problem with the rim, or unbalanced tire, you'll feel the vibration when coasting with the engine at idle.
I also suspect that you are just lugging the engine. That's easy to do when you first get the bike.
