Need jet size advice
I have the Vance and Hines straightshots and the Sceamin Eagle air intake.I used 180/45.I tried 175 but it was better with the 180.Also the air fuel mixture screw needs adjusting.It is under the plug that has to be drilled out.The whole job is pretty easy as long as you follow the instructions on this site.
I have cycle shack slip on's and Screamin Eagle a/c...45 and 180 almost 40,000 miles with that setup...works pretty good.
Here are a couple of helpful articles on this:
http://www.harley-performance.com/ha...arburetor.html
http://www.harley-performance.com/ha...r-jetting.html
