drag pipes on an 07 1200
Drag pipes will cause a loss of torque from a little above idle through at least 3500 rpm, give-or-take. There are some things you can do to alleviate the torque loss. Read here: https://www.hdforums.com/forum/useless-threads/7223-drag-pipe-how-to.html
The link is a little hard to read as it has some punctuation "junk" in it left over from when the forum got hacked.
Drag pipes were designed for just that, drag raceing. great pipes for wide open throttle. not so good for much else other than noise unless you find some baffels. You might give Bassani pipes a look.they sound great and get better as they "age" from rideing. Will wake the neighborhood up when you open her up too.
