'94 883 problem
Old 09-14-2008 | 07:40 PM
1flhtk4me's Avatar
1flhtk4me
Default '94 883 problem
Thinking of buying a '94 883 for my wife.15000 miles price may be $1600 to $2000.Depends on negotiation.
The bike runs but at idle it's mostly running on the back cyl.I can hear the front cyl kick in once in a while.After the engine was idling for about 5min.,the rearjug was hot and the front was not.
So what may be the probem?I'm thinking fouled plug,wiring,plug wire.coil or stator?
What would a stator cost?
I can do the work myself.
Just trying to figure in other costs.
Any help would be great!
Old 09-14-2008 | 09:15 PM
Gpsjr10's Avatar
Gpsjr10
I would surely pull out both plugs and see what is going on, the condition of the plugs may give you a good indication of a problem with the engine. But may be as simple as a new plug wire or the plugs themselves. Wouldn't be the stator unless you have a charging problem. For the price of the plugs, bring a new set with you and change them prior to purchasing the bike. $4 for Autolite plugs would be worth it to me. (Set a low price since it doesn't run right, pay the man, change the plugs and ride it home.) Maybe.....
My friend did that with a car once, car wouldn't start, fuel pump wouldn't work... gave the man just over scrap price, thought a minute, opened the trunk, reset the fuel-pump cut off switch and drove it home.... He said you should have seen the look on the seller's face.... priceless.
Old 09-14-2008 | 10:17 PM
1flhtk4me's Avatar
1flhtk4me
Going to pass on this one!
Old 09-15-2008 | 04:30 PM
Sick1200's Avatar
Sick1200
$1600 and you're gonna pass!?!?? For that price you could buy it, put in a whole new bada$$ elec. system, 1200 kit and still come out on top. If it aint the plugs, my guess would be the coil, which is only around $80 or so.
Old 09-15-2008 | 08:39 PM
HOTLAP's Avatar
HOTLAP
As sick says the price is right, a quick 5 minute compression test would tell you if there is a problem with the cylinder/piston/valves.
If that checks out good then you know it's a minor electrical problem, maybe plug/wire/coil.
The Outlaw
04-28-2013 07:49 PM
Vdoubleyou
05-07-2012 02:00 PM
Grofb
07-19-2011 03:33 PM
Harley Joe
10-27-2008 11:06 AM
shadetree
10-17-2007 09:09 PM
