XL1200C Front Rim/Tire
1. Going to a 2 inch smaller tire only changes the height by one inch. Ther's only 1 inch of difference on the bottom (from hub to ground). The other inch is above the ground.
2. Totally depends on the tire, not the rim. It the OD of the 21 inch tire is the same as the OD of the 19 inch tire you won't have any change in height. Notice I said TIRE, not RIM. The larger rimmed tire can have less sidewall to equal out in height.
All will depend on your tire selection.
Nope. 2 things:
No, you don't have to worry much about a cast wheel loosing true. They don't tend to bend, they break if ya smack them hard enough.
You lucky dog, I just noticed they cost $850.00 new. Thats something that has to wait, my main focus is getting the bike paid off as soon as possable.
Agreed and to go even better, you can fit a 110/90/19 on that same rim no problem. My Roadster came ith the 100/90/19 57H and it now has the 110/90/19, which has not only changes the ride but that front end flat sticks.
