Screamin Eagle VS stock pipes
Hi everybody,
I have a 2005 883 that I bough recently and would like to change the stock pipes. I'm looking to buy legal pipes. Do you know if there is only Screaming eagle which are legal ? Any other legal brands ??? Also, Are there any of you who changed stock pipes for screaming eagles ones ? Is there a big difference with the sound and power if you compare with the stock ones ? Do you suggest me to change the air box at the same time for a Screaming eagle ? Will it change power ?
I'm new with harleys and any advice will be appreciated..
thanks,
Martin
thanks,
Martin
I had the SE Stage I AC & SE Street Performance Slip-Ons installed. This required a remap since mine is fuel injected. Mine is an '08 XL1200N & I couldn't be happier. The sound is MUCH better than stock, with the nice Harley deep rumble I was looking for. If you want just LOUD, you may want to go a different direction. This bike was wicked quick before, but now it will absolutely jump out from under you. I also had it Dyno tuned. Again, the best money I've ever spent.
What region are you in? Are you required to meed California emissions? If so, then that might warrent some closer looks.
How's that affect the warrantee? I'd like to stay stock until the warrantee is up just to be safe.
Yes to all of the above. California is it's own little entity so go through the dealer for "CA approved" pipes and have them do a reflash upgrade for the EFI (if equipped) or the re-jet. Better power & gas mileage. And leave the evap cannister alone: it doesn't rob you of HP and will save you legalities later.
I live in Kentucky, but my understanding is that the SE Street Performance Slip-Ons are 50 State legal. Parts were purchased from & installation done by the dealer, so it shouldn't affect the warranty.
Tucker24189
08-27-2011 10:11 PM
