Shifting clunk
Old 08-21-2008, 07:08 PM
Paflyfisher's Avatar
Paflyfisher
Paflyfisher is offline
Default Shifting clunk
I bought an '05 1220c with 7000 miles on it. When I shift up or down it seems to make a clunking noise. Since this is my first Harley, I don't know if it's normal or not. The bike runs great and shifts fine, just clunks when i shift.
Old 08-21-2008, 07:12 PM
Curt1953's Avatar
Curt1953
Curt1953 is offline
Harley's are surpose to shift like that, that way you know it goes in gear.
Old 08-21-2008, 07:13 PM
plysat's Avatar
plysat
plysat is offline
If it's shifting OK, I vote for perfectly normal. Every HD I've ever known clunks into gear. :-)
Old 08-21-2008, 07:22 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
They clunk, If it seems a little extreme you might want to check your gear oil level and believe it or not it's just as easy to change it. Do you know the last time it was looked at or changed? Drain it out the bottom and then fill it back with 32Oz's of recommended gear oil right in your little primary chain inspection cover. If you have a service manual you can also check your chain tension while your at it just to make sure.
Old 08-21-2008, 07:40 PM
Paflyfisher
The dealer changed the oil and filter and the transmission oil before I picked it up. I have put about 800 miles on it in the last month. Thanks for the responses and I guess they go clunk. I can live with that.
Old 08-21-2008, 09:17 PM
dmercer's Avatar
dmercer
dmercer is offline
I actually enjoy the clunk. It's the sounds of a good, hearty gear mesh
I remember reading another thread about this somewhere and someone commented they'd spoken to one of the HD engineers at a MoCo event who said they intentionally leave the clunk in the trans, though I suppose I need a cite for that to be taken seriously
Old 08-21-2008, 10:23 PM
CapnAdventure's Avatar
CapnAdventure
CapnAdventure is offline
Heh, heh...I'd worry if it weren't clunking.
Old 08-21-2008, 10:53 PM
JosephGarcia's Avatar
JosephGarcia
JosephGarcia is offline
mine clunks into first and second but into neutral and every other gear its very quiet and smooth.
Old 08-22-2008, 05:15 AM
Z06_Pilot's Avatar
Z06_Pilot
Z06_Pilot is offline
Oh yea, the clunking is part of the Harley experience. no other tranny does this in my experience.
rode a v-rod recently and one of the many reasons I didn't like it was trying to figure outif I was in gear or not. very little feedback through your foot when shifting.
nothing better than sitting in neutral at a light, then banging it into first: clunk, go!
Old 08-22-2008, 07:18 AM
fredp's Avatar
fredp
fredp is offline
6th Gear
Supposed to clunk when it shifts, just don't neglect the Transmission oil changes and it'll be fine.
Quick Reply: Shifting clunk
