Electrical question. Possibly easy to answer
Old 08-19-2008, 06:33 PM
Certainteed's Avatar
Certainteed
Certainteed is offline
Default Electrical question. Possibly easy to answer
I need to be able to turn all the lights off. Anyone have experience with modifying the electrics in this manner?
Old 08-19-2008, 06:36 PM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Shut the key off.
Old 08-19-2008, 06:38 PM
Tommo's Avatar
Tommo
Tommo is offline
Pull the fuse?
Old 08-19-2008, 07:02 PM
Certainteed
Originally Posted by xFreebirdx
Shut the key off.
The engine shuts down, which is an undesired result.
Old 08-19-2008, 07:06 PM
Bluesssman's Avatar
Bluesssman
Bluesssman is offline
It is illegal to operate a motorcycle without lights, especially the headlight.
Old 08-19-2008, 09:06 PM
Certainteed
not in ky. thanks for posting.
Old 08-20-2008, 12:50 AM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
For what reason would you want to ride without lights?
Old 08-20-2008, 01:43 AM
plysat's Avatar
plysat
plysat is offline
Regardless of *why* you want to do it, I'd get ahold of a service manual. The wiring diagram will tell ya which circuits (pretty sure running/brake and headlight are separate) you need to put a switch on. Sorry for the vague advice.
Old 08-20-2008, 03:32 AM
JosephGarcia's Avatar
JosephGarcia
JosephGarcia is offline
my sporty ignition has three positions.
1- off
2 - ignition on only
3 - everything on.
it comes in handy and i use number 2 during the day to save the battery, my batt is WAY WAY WAY past its service life (more than 10 years old, which i assume is longer than they are supposed to last)
maybe you can retrofit an old ignition switch and make the wiring so it acts the same as the older bikes.
EDIT by the way, when i am in the ignition only mode, i have no running lights, but the brake light and turn signals still work if i activate them. which means they are on seperate circuits than the running lights. hope that helps.
Old 08-20-2008, 05:41 AM
dbleagle's Avatar
dbleagle
dbleagle is offline
Isolate the light wires run them through a toggle switch...
Ahhhhh... trying to out run the law... or just bootlegging?... ;-)
Charlie D.
Quick Reply: Electrical question. Possibly easy to answer
