Sportster Oil Change / Tune Up
man it is listed right on the top of your threads on here as a sticky... your mod on this section is awesome! he finds some great stuff!
http://www.bikernet.com/sportsters/
the how to:
http://www.bikernet.com/sportsters/P...asp?PageID=622
the how to:
ooh BS the 1000 mile service is all JACK!chainge the fluids, adjust the clutch, check bolts on the bike to ensure they are tight, check the spokes (take a screw driver handle and bop each spoke, they should all "ting" the same if one has a low sound tighen it till it gives the same "ting") then just lube your cables, (get some cable lube, drop 2 - 5 drops down each cable at the lever... easy) well there you go... 1000 mile service... ahh and some people actually PAY for that! ooh ya you can change you air filter as well...
