Shifting Problem
Shifting Problem
My wife has an '04 883 Custom and she is having some shifting issues. She says that when she shifts into the higher gears, third and up, she has to hit the shifter twice to get it to shift. She says it does it after the bike has warmed up a bit. She will pull up on the shifter and she does not hear the gears change, when she hits it again they change. I changed the transmission fluid, but that did not solve the problem. Anyone have any suggestions?
adjust shift rod, and also make sure the bolts on the inspection cover are good.. i have seen it where those bolts are too long and cause a grinding and cause hard shifting... why you ahve it apart adjust that clutch... Loosen the linkage on the down tube, back the bolt out on the clutch basket, loosen the set bolt, screw it back in till it seats and then 1/4 turn out, lock it down with the bolt... then tighten the clutch play on the linkage on the down tube so you have just a very little play in the lever...
