turn signal problem
Could be a number of things. There could be corrosion in one of the left turn signal housings, short in the left turn wiring, or corrosion at the left turn signal wiring at the connector under the tank, or the left turn switch could have gone bad. Have you bottomed out lately? You could have rubbed/tore one of the wires under the rear fender.
