rejetting 1220c
RE: rejetting 1220c
If you were doing it with a DJ kit, you'd want a 45 slow, 180 main, and 3.5 turns out on the mixture screw. You wouldn't necessarily need a bigger main jet since you would have a new needle and would have drilled the slide.
But, if you are just changing jets, start with 45 slow, 180 main, 3.5 turns and see where you are at. Bet it'll be right on at idle. The only adjustment would be with the main jet. If you think you are still running lean, and have come out 3.5 turns, go bigger on the main jet. Jump to a 185, 3.5 turns, and recheck.
Its kind of a guessing game without a jet kit but its doable. Just have to tweak it a little. Get on a dyno if you can once you have new jets in.
Good luck.
Good luck.
ecaldwell78
08-28-2008 09:14 AM
