GPS on Sportster pics
Old 08-05-2008 | 02:38 AM
Teek's Avatar
Teek
Default GPS on Sportster pics
Forum still broke so cant do too much detail but here are some bad night photos
Need to clean up the connections a little but it works
Teek
Old 08-05-2008 | 02:47 AM
Teek's Avatar
Teek
Default RE: GPS on Sportster pics
Crap! Cant post more than 3 lines! Need to get larger heat shrink wrap to fit over the plugs and totally cover and weatherize the wiring. The blue stuff you see here just didn't quite get it right. Provides some protection but would not want it to get wet right now.
Old 08-05-2008 | 02:53 AM
stonecold1224's Avatar
stonecold1224
Good job, should work like a champ.
Old 08-05-2008 | 02:59 AM
Teek's Avatar
Teek
extension cord is routed from 12V adapter down in front and under ignition through the cable bracket under the tank suspended by whatever cables and lines I could find over to the other side between tank and nose of seat then plugged into pigtail. Under seat is the excess.
Old 08-05-2008 | 03:16 AM
Teek's Avatar
Teek
It's not intended to be wired permanently but I think it's secure enough and versatile enough for what I want to do with it. I'm thinking of putting heat shrink on the exension cord to protect it more from engine heat. Any other ideas? I wanna keep that cord as thin and flexible as I can.
Teek
Old 08-05-2008 | 08:33 AM
Terp84Alum's Avatar
Terp84Alum
Can you post more info?
Old 08-05-2008 | 08:45 AM
128auto's Avatar
128auto
Impressive! Teek, you did a great job.
Here is mine.
Old 08-05-2008 | 08:57 AM
Terp84Alum's Avatar
Terp84Alum
I would be afraid my GPS would vibrate off the mount on my handlebars.&nbsp\\; The actual mirror part of one of my mirrors vibrated off and hit me in the chest one day.
Old 08-05-2008 | 09:02 AM
128auto's Avatar
128auto
For a soild mount Sportster, you do get more vibration. Get the ram mount, it will dampen the vibration a bit. As you see in my pictures, I use a Kuryakyn bar clamp for mounting my GPS, works great. I also have a ram mount setup, it seems to be better, less vibration.
Old 08-05-2008 | 12:10 PM
HOTLAP's Avatar
HOTLAP
128auto, did you ever get that glare shield and if so how does it work in sunlight.
