PCIII Update
PCIII Update
My bike was runnin pretty bad when cold so I thought I would try a few things....
My PCIII was originally sent with a custom map from Jamie at FuelMoto. I thought I would try the map for my setup at Dynojet.com... after sending the map I went for a ride and the map was NOWHERE AS GOOD as Jamie's map, so I went back and reloaded the original map. I also reset the throttle positions with the bike at FULL OPERATING TEMPERATURE. The result? It now runs INCREDIBLY WELL!!!!
If you are gertting any popping when warm MAKE SURE to reset your throttle positions...and do so when you're at FULL operating temperature.
RE: PCIII Update
http://fuelmotousa.com/faq.htm
Tutorials on setting throttle position toward bottom of page.
Check it out!
Check it out!
