78 ironhead oil blowing out exaust pipe
Well I have traded for a 78 sportster its been setting up \\; for several years and I was told it was supposed to be rebuilt by a place out of tenn. the guy I got it from says several months \\;after the rebuild it started pumping oil out the exasust pipe .Yes the exasut pipe, its my understanding when you start the \\; bike it pumps oil out the exasust pipe I have pulled the oil pump and under the check valve the \\;O ring was missing, according to what I have seen and read it is supposed to have two O rings and the one under the check valve is gone . Now heres my question ? Will that O ring missing cause the oil to bypass to the engine and pump out the exaust ? \\; I can be contacted directly at \\; \\; \\; \\; \\;  \\;charleykoal1@yahoo.com \\;
