Occassional starting problem.....
Also posted in General Chat-
Three times now I have gotten on the '08 nighty and when I push the start button, nothing happens for the first several pushes \\;and then \\;it seems to struggle a little bit to start. \\; Yes it is in nuetral, clutch in and run switch on. \\; Before it actually starts, nothing at all happens, no whirr, no tick, no grind and \\;lights don't dim. \\; Just acts as if the switch or relay isn't working.
It did this a couple days ago, then no problem for a couple days. \\; It started fine yesterday morning, then again at 5 pm. \\; Then it hesitated to start at 9:30pm and this morning at \\;7am it really took a few times to get it. \\; Just tried again and it started up no problem!?
Could this be condensation/dew forming in the switch housing? \\; It seems that the only times it has happened were in the morning or early evening, times when dew would start/ has formed. \\; Or maybe could the nuetral sensor/ shift indicator or whatever won't let the bike start in gear is glitching? \\; Whattya think?
RE: Occassional starting problem.....
I had intermittent starting problems, it turned out to be the starter relay. The times it doesn't start, you might be able to hear a faint click if you put your ear on the seat. If you hear a click every time you push start, it's probably the starter relay. (Not to confuse clicking from the starter solenoid). Starter relays are easy to replace and there only about $15.
