Help with Throttle cable replacement
I have a 98 1200s sportster. \\; I replaced the clutch cable with a braided line and now I am attempting the throttle/idle cables. \\; I removed the throttle cable, but found that the stock cable is held into the housing by a c-clip. \\; The cables I purchased are threaded at end that would go in the housing. \\; Did I purchase the wrong cables or are most sportster throttle cables threaded? \\;
