883 exhaust
RE: 883 exhaust
ORIGINAL: jaredhd
could someone pls tell me what to look for a loud exhaust. short, long, 2 to 1, 2 long pipes, whats the loudest and what makes one louder than the reest. could you please fwd me a link to the pipes. thanks
http://co-japan.com/sportster/
Cheers,
Mark
RE: 883 exhaust
ORIGINAL: mthomas000
Well, don't know if this will help, but I've got a listing of a number of pipes on my sportster web page that I took a look at before making the decision to go with Thunderheaders. For a 2 into 1 system they are very good and seem to be prefered by a lot of high performance shops. Are they loud... yeap, but very different in sound to what you would get with 2 into 2 systems.
Cheers,
Mark
ORIGINAL: jaredhd
Cheers,
Mark
RE: 883 exhaust
In general only... longer pipes with a bigger inside diameter will give you a deeper sound than shorter skinny pipes. Baffles can complicate this, but for illustration, think of a pipe organ. The longer, bigger pipes stretch the soundwave to give it a deeper note than shorter pipes. As for volume, drag pipes will be the loudest w/ no baffles, but a system with a lot of internal baffeling (stock muffs) will give you the quietest volume.
RE: 883 exhaust
They are a million different loud pipe's but for example straght pipe's are loud but they do not have the best sound to them imo and you will lose a lot of power. A 2-1 is loud but sounds completly different than a straight pipe. And in general short pipe's will be louder than long pipe's and short pipe's may also shoot fire ***** if you are not careful.
RE: 883 exhaust
ORIGINAL: AZFlyingDiver
Loudest would be drag pipes (straight-through, short, no muffs), although a drop-in low end torque would be the sacrifice for the "most" sound...
