Any oil change tip's
07-20-2008, 05:41 AM
I'm just getting ready to do the first oil change on my \\;girl friends \\;07 \\;883L. Is there any tips or tricks you have found to make the job go easyer? I have a service manual for her bike and am pretty handy with a wrench, I've done 100% of everything to my FLHRS.
Thanks guys.
07-20-2008, 06:00 AM
RE: Any oil change tip's
Usual common sense stuff. Have the right filter wrench. A few rags for spills. Warm the oil but, no too hot. Use a rug or padding on the floor if you are not using a lift.
07-20-2008, 10:56 AM
don't remove any bolts from the bottom of the engine
07-20-2008, 11:09 AM
Quote:
ORIGINAL: schumacher
Unless you are changing the primary/Tranny fluid.
07-20-2008, 11:11 AM
I know a guy that did that after he first bought a Sporty. Called me up and asked...what did I just drain? it's not oil....
[8D]
07-20-2008, 11:32 AM
07-20-2008, 10:22 PM
drill a hole in the filter to get the oil out before taking it off. It's a real mess if you don't.
07-21-2008, 10:30 AM
I use a piece of construction paper and fold in a u shape. stick it under the filter and losen no oil gets on the bike at all.
07-21-2008, 11:03 AM
+1
07-21-2008, 03:22 PM
Don't over fill it.
