Sporty Carb Question (not jetting)
I recently bought a '92 1200 Sporty. \\; It had been sitting for quite some time, but started okay. \\; But, when opening the throttle it died &\\; fuel spilled out the bowl overflow hose. \\; Had the same problem with my FLH, so I thought the jets were clogged. \\; I took the carb apart, cleaned it, &\\; replaced the jets (stock sizes). \\; It actually wasn't too dirty &\\; the old jets looked fine (i.e., not clogged). \\; Put it all back together. \\; Same problem- it starts, but when I open the throttle it dies &\\; fuel comes out the overflow hose.
Any ideas?
Thanks.
Any ideas?
Thanks.
RE: Sporty Carb Question (not jetting)
It was the nozzle from the accelerator pump.... \\; No amount of carb cleaner (sprayed into nozzle from pump side) cleaned it out. \\; I ended up sucking it clear from the nozzle end- an amazing amount of gunk in that narrow tube. \\; Now it runs fine....
diddlyd
Carburetor Related
12-19-2015 11:17 PM
