Porkster Tank
Old 03-11-2006 | 11:35 AM
JKDJose's Avatar
JKDJose
Default Porkster Tank
I bought the Porkster Tank and will be doing the prep work and painting myself. I have a bit of auto body and painting experience but haven't done it in years. Anyone know of a good quality lacquer paint in a spray can that they can recommend? Any input is greatly appreciated. Oh I will be painting it black and deciding on putting flames on it or just buying a harley sticker. (still up in the air)
Old 03-11-2006 | 12:24 PM
ronn39's Avatar
ronn39
Default RE: Porkster Tank
If you've done autobody painting, then you know it's near impossible to get a really decent finish with spray can paint, no matter who makes it. The primer in spray cans works OK if you do the finishing sanding on it. If you know a good shop in your area, getting the job done with the right stuff shouldn't cost much at all and be worth the "factory finish."
Old 03-11-2006 | 12:50 PM
Ironhead's Avatar
Ironhead
JK, if you have a little experience, you'll know you can't get the painted finish you want without a hellova lot of extra prep work and wet sanding. Personally I've never had much luck with the spray-can application.
I painted mine a little over a year ago and was wanting to use laquer and the paint shop talked me out of it. They reccomended Urethane. So I went with it.
It worked better than the Clearcoat/Basecoat, and more durable than laquer.
Check out my link.
Old 03-11-2006 | 04:32 PM
JKDJose's Avatar
JKDJose
Darn. I figured the cans were still garbage, I was hoping someone would have something that worked though. There's a guy around the corner from my house who paints bikes I will ask him how much he will charge to paint the tank.
Yeah, the prep work takes a lot of time and you have to be really patient. I expect to do lots of wet sanding, etc... I will just take my time until it is perfect.
Old 03-11-2006 | 04:44 PM
inthechateau's Avatar
inthechateau
JD, where are you located. If you are not too far from Maryland I may be able to hook you up with a gentleman I work with that does terrific work on the side. PM or e-mail me and see if I can't help you out. The spray bomb will leave you very disapointed with the results. inthechateau@gmail.com .
Old 03-19-2006 | 11:16 PM
JKDJose's Avatar
JKDJose
Took the tank to a the local body shop here. I will post pics when it is done.
Old 03-20-2006 | 03:59 AM
Ironhead's Avatar
Ironhead
Oh yeah... looking forward to the pics!
Valleyofthegun
Powdercoat & Paint
03-30-2020 01:10 PM
electra_boogaloo
Powdercoat & Paint
07-25-2017 08:20 PM
nathan-hd48
04-22-2015 08:49 AM
HarleyDynaWide
02-11-2015 12:35 AM
11bDad
Powdercoat & Paint
01-26-2011 04:06 AM
Quick Reply: Porkster Tank
