Handle Bar Swap
Old 07-12-2008 | 10:53 PM
HDXXX's Avatar
HDXXX
Default RE: Handle Bar Swap
I did consider bending the brake line, to save&nbsp\\;\\\\\\;the price of the new brake line which&nbsp\\;\\\\\\;anywhere from&nbsp\\;\\\\\\;$55.00 to&nbsp\\;\\\\\\;$70.00, and&nbsp\\;\\\\\\;I am sure I'll have to reroute the throttle cable outside as well.
Old 07-13-2008 | 07:12 PM
higg47's Avatar
higg47
Replaced my 1200C bars with a set Dyna low bars and changed the bars only. Brake line long enough if you fab a new clip. Much more comfortable and no ape look.
Old 07-13-2008 | 10:27 PM
HDXXX's Avatar
HDXXX
Do you have a close up photo of the clip? I could use a good idea.
Old 07-14-2008 | 05:23 PM
higg47's Avatar
higg47
Fabricated clip from wide wire tie used by phone companies and power service companies.&nbsp\\; Taper ends a little for looks used original screw in threaded hole from old clip.&nbsp\\;&nbsp\\;Photo of bars shows they are wider, a little higher and&nbsp\\;a little more pull back.&nbsp\\; Very comfortable.
&nbsp\\;
PM me your email address and I will send pictures.&nbsp\\; The forum way is not working tonight.
Old 07-16-2008 | 08:13 PM
HDXXX's Avatar
HDXXX
Nice job on the clip you made. The brake line looks good that way. I did the bars today and ended up putting a reflector holder from a bicycle as a temporary clip for my brake line. I bit the bullet and ordered a new one.
Turbomunkey
12-11-2017 07:31 AM
cjandmm
10-21-2016 06:22 PM
dispatch-rider
04-13-2015 10:31 AM
Leonards48
02-18-2014 03:40 PM
Gee
11-04-2011 04:30 PM
Quick Reply: Handle Bar Swap
