warm up before riding
RE: warm up before riding
Full choke, 30 sec warm up &\\; do the rest of the warm up gently \\;riding until I have the choke all the way in. \\; My neighbors would get pretty annoyed if I let the bike warm up for 5 minutes. \\; You will tend to get more carbon build-up with that much idling also.
Same here. I start it in the garage and it warms up for as long as it takes me to back it out, close the door, fasten the helmet and gloves. Probably no longer than a minute maybe 90 seconds.
Probably a little quicker with the car. Start it, fasten the seat belt, set the radio and I'm gone.
If you notice, the oil pressure light goes out immediately. You know you have oil pressure. Now add another 10 to 15 seconds for it to pump through the engine. It's as oiled as it's ever going to get.
It shouldn't take more than a few seconds for the oil to circulate. My 08 1200 will falter in very cold weather if I don't let it run for about a minute max. Then I'm careful not to push it too hard for 2 or 3 miles. Until the engine is up to temperature, the head bolts aren't fully tight and you are more likely to \\;blow a gasket.
