Removing baffles from SE II's
RE: Removing baffles from SE II's
Removing the baffles will give you a hybrid drag pipe/small megaphone effect and you'll lose low and mid-range torque and speed by removing the back pressure. \\; Best to put in a set of BCT baffles and gain the punch in the low and mid ranges while giving your bike some \\;of the best sound you'll find.
Check 'em out:
http://www.bigcitythunder.com/pages/...rformance.html
Check 'em out:
ORIGINAL: plevine1
Another option is to modify the existing baffles. Pull them out and redrill all the holes to 1/4 inch. You will gain sound and not effect power.
That is true, but there are two benefits to the BCT's you won't get by doing this - take it from me.
Those benefits are increased low and mid-range performance from the BCT's and no "tinny" sound from the BCT's that you do get drilling out the stock SE II baffles.
ORIGINAL: Thumper26
ORIGINAL: plevine1
You are 100% correct on the BCT'S. I did the mod to my SE II's only because it was a cheap solution. When I have a few extra bucks I'll get the BCT's
