what oil should i use?
Old 03-10-2006, 02:55 AM
chromeyellow78's Avatar
chromeyellow78
chromeyellow78 is offline
Default what oil should i use?
Its that time of year again.. anyone have a good 2cents on if i should use the regular or synthetic oil in my 01 XL 883C? I have been told that the bigest difference is the cost.
Old 03-10-2006, 10:28 AM
molsenice's Avatar
molsenice
molsenice is offline
Default RE: what oil should i use?
another oil thread - MY advice use what fits in your comfort level - as for cost - synthetic is actually cheapear since you arn't changing as often.
Old 03-10-2006, 11:59 AM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
I run synthetic and still change my oil every 2,500 miles. To me, I have a $15,000 machine, why use something less than the best to save $10 an oil change. I'd suggest using either Amsoil or Mobil 1 V-twin 20W-50.
Old 03-10-2006, 12:29 PM
molsenice's Avatar
molsenice
also remembered the synthetic has better thermal protection
Old 03-10-2006, 10:06 PM
shamboogiebanger's Avatar
shamboogiebanger
shamboogiebanger is offline
15w-50 or 20w-50 ?? i plan on using mobil-1, but which one?
Old 03-11-2006, 01:08 PM
rpoteau's Avatar
rpoteau
rpoteau is offline
You should use Mobil1 20w-50. Usually runs me 8.99 a quart but I think its worth it.
Old 03-11-2006, 03:35 PM
1200c's Avatar
1200c
1200c is offline
Use what's avilable and what you are willing to pay for. I personally run synthetics and when it comes to those you can't go wrong with amsoil or mobil1 (use the one that's more commonly avialable and/or cheaper). Your manual recommends 20w-50, but some people have gotten away with running mobil1 15w-50. I don't find synthetics to be more expensive because I just double the oil change time.
Old 03-11-2006, 07:52 PM
96customsporty's Avatar
96customsporty
96customsporty is offline
Just a quick one how often are you guys changing oil and filter when using synthetics???
Old 03-11-2006, 08:04 PM
Snarly's Avatar
Snarly
Snarly is offline
ORIGINAL: 96customsporty
Just curious, what does the factory say in your manual? Might be a good option. I go by it.
Old 03-11-2006, 08:49 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
2500 miles , oil and filter.
Quick Reply: what oil should i use?
