So i go to start the bike and when i turn the key to ignition everything looks normal, engine light goes out.....hit the starter button and all i hear is a click! So later in the day i tried it again and when i put the key in ignition i get nothing at all now as far as gauge lights or it even trying to start! \\; When i put the key in accessory everything turns on though.......any ideas??
The first thing I'd do is tighten all 4 points of the battery cables. \\; Don't look them over, don't check them, put a wrench on everyone and snug them up well.
After everything is tightened up, recharge the battery. \\; That is the most likely cause. \\; A four year old battery may still be OK, just run down. \\; Use a Deltran Battery Tender Jr to keep the charge up when the bike hasn't been used for awhile.
