se II's baffle removal question
REmoved the baffles on my 05 1200 custom....way too loud, have a headache after a 40 minute cruise. I want louder but not that loud.
Questions:
1) can I remove the packing and just put baffle back on for a louder sound? but not as loud as with baffles removed?
2) I had the carb done and airbreather with the SE 2 slip ons..now removing packing, will that lean me out??
Thanks!
Questions:
Thanks!
RE: se II's baffle removal question
Are you sure you have SE II mufflers? \\; I ask because there are two bolts that hold in the baffle on each muffler.
To remove the baffles on SE II's, you take the two bolts out, and then pull the baffles out. \\; One was wedged in pretty well on mine, so I had to remove the muffler and drive a 1" dowel from the other end against the baffle to remove it. \\; BCT baffles simply bolt back in place using the stock bolt holes.
as thumper stated for removal....but mine behind baffle have a steel tube packedf in steel wool type of stuff....I took them and baffles out...too loud...baffles out and packing in..still a little too loud...baffles in and steel packing out...seems quite nice at idle (just started raining so I can not take it out)....with BCT's do you remove the packing?
Yes Im sure I have screaming eagle mufflers, they are stamped so on the side.. \\; I stand corrected though it isnt studs and nuts on the bottom, it was a small bolt, but I only see one bolt on the forward muffler not on the rear, there are a couple of holes on the \\; rear muffler, but no bolt. \\; I took the bolt out of the forward one and the baffle wont even move a fraction. \\; What am i doing wrong????
My SE II mufflers, that I bought new in 2006, came with the baffles held in place with two bolts on each muffler. \\; There was NO "packing" material of any kind in the SE II mufflers, their baffles, nor the BCT baffles I subsequently installed. \\; SE II mufflers were discontinued in early 2007 and replaced with SE mufflers which are 50-state legal and different ii internal design. \\; SE II's are stamped "for off-road or competion use only" (or something similar).
