Chug, chug, chug????
#32
RE: Chug, chug, chug????
ORIGINAL: travroc
I shift to
2nd at 25mph
3rd at 40mph
4th at 55mph
5th at 70mph
or approximately 4k rpms. \\\\\\; We hit our limit at about 6K, so there is plenty left. \\\\\\; Some of you are shifting way to early. \\\\\\;
I shift to
2nd at 25mph
3rd at 40mph
4th at 55mph
5th at 70mph
I shift generally around those same points, too. Ignore what the owner's manual says about shifting: HDs recommended shifting speeds sound more car-like. Get that thing up in the powerband.
40mph in 5th sounds scary.
#33
#34
ORIGINAL: LoneRyder
LOL welcome back a**hole!  \\; I would've posted my 1-up numbers but you would've got on me for showin off.
ORIGINAL: 6o66er
Aside from the 2up thing........Yeah. That's pretty much it.
ORIGINAL: LoneRyder
1st gear to 20mph
2nd gear to 40mph
3rd gear to 60mph
4th gear to 75mph
5th gear to 125mph
Anything less than that and your are pu**y! \\; Oh and thats 2-up!!
1st gear to 20mph
2nd gear to 40mph
3rd gear to 60mph
4th gear to 75mph
5th gear to 125mph
Wouldn't know personally...I ain't got a speedo or a tach....I just wait for the pucker and the **** shiver to run down my leg and knock it up a gear before somethin falls off. [8D]
#35
ORIGINAL: 6o66er
You mean like....1st to 25, 2nd to 45/50, 3rd to 70, 4th to around 85, and 5th to HOLY HELL I'M GOING ****ING FAST!!!!!.......? \\;\\\\\\;
ORIGINAL: LoneRyder
LOL welcome back a**hole!  \\;\\\\\\; I would've posted my 1-up numbers but you would've got on me for showin off.
ORIGINAL: 6o66er
ORIGINAL: LoneRyder
1st gear to 20mph
2nd gear to 40mph
3rd gear to 60mph
4th gear to 75mph
5th gear to 125mph
Anything less than that and your are pu**y! \\;\\\\\\; Oh and thats 2-up!!
1st gear to 20mph
2nd gear to 40mph
3rd gear to 60mph
4th gear to 75mph
5th gear to 125mph
Yeah that sounds about right... Numbers a bit low...no RPM limiter here. \\;-)
#37
I intentionally hit the rev limiter once. Stock 1200L with winshield and saddlebags, I weigh about 140 lbs...2d gear hit the rev limiter at 65 according to the speedo. I wasn't in the position to take it any further as it was the exit from the toll booths at DFW Int'l Airport.
MINIMUM for me is 20 in 1st, 30 in 2d, \\;35 in 3d, 40 in 4th, and 50 in 5th. That's still too \\;slow, but that's minimum for me. NORMALLY I'm with \\;most \\;everyone else, depending on traffic and whether \\;I'm entering the highway on ramp...20-30 in \\;1st, 30-45 in 2d, 40-60 in 3d, 50-70 in 4th, and \\;I'll get into 5th at 60 or above. After that I'll try to find that elusive mythical "sixth gear"!
Teek \\;
Teek \\;
#40
I'm new to the 1200N. \\; I find myself on roads that are going about 50-55mph and I thought it was a good idea to be in 5th gear. \\; At this speed I may go for 20 to 30 miles before slowing down or speeding up. \\; Would you stay in 4th gear all this time? \\; Or shift into 5th? \\; Thanks for the input.
