Hands Asleep
RE: Hands Asleep
I had the same problem with my hands, "death grip" is a good term, I had to learn to loosen my grip because I'm a new rider. \\;My Sporty came with the stock grips (small diameter) I put 1.5" diameter grips on, even with the death grip my hands do not go numb anymore.
chris.
chris.
RE: Hands Asleep
I also have ISO grips and they are great. \\; I \\;had carpal tunnel syndrome in both wrists, but only the left has been operated on so far and I have NO problems with that hand at all. \\; The right hand, yet to have the surgery, is a constant problem but I'm convinced once I have the carpal tunnel fixed in my right wrist, I'll be totally OK in both hands.
RE: Hands Asleep
Good advice in replacing the grips, if they are stock, and loosening that death grip. \\; Another thing to look at is your seat. \\; I replaced my stock seat with a Mustang, which has excellent lower back support. \\; Most of my riding is in the freeway and the stock seat with minimal to no back support at all made me feel like I had to grip harder just to hang on at freeway speeds. \\; With the Mustang, much more relaxed and very light grip, even at 80mph.
RE: Hands Asleep
Put a Throttle Rocker on the right grip, and use a padded palm glove. I don't give a rip what people say about my glovesfour pair of them to fit every season. I use the mesh workout gloves the most because they are cooler and have a good padding in the palm. The only riders who don't wear gloves are the ones that are going down. The rest of us have been down and know better.
Take a long ride with a good experienced friend leading the way. That way you don't have the option of stopping. You will become conscious of your tense grip and will be forced to relax your grip on the open road. The weight of your right hand will be enough to keep the bike up at cruising speed.
RE: Hands Asleep
ORIGINAL: Gpsjr10
 \\;I did see someone that had these jell filled covers that slip over your stock grips, he said they work great and they were like $12 or something. \\;\\\\\\; Maybe that will work for you.
I have something like those. They are called Grip Puppies from www.casporttouring.com \\;$8 a pair. They seem to work ok.
RE: Hands Asleep
ORIGINAL: Gpsjr10
I have the ISO grips on mine, They help quite a bit. \\;\\\\\\; I did see someone that had these jell filled covers that slip over your stock grips, he said they work great and they were like $12 or something. \\;\\\\\\; Maybe that will work for you.
RE: Hands Asleep
If you're an old fart like most of us, it's a combination of things.
I had to sort thur several seats, bars and grips before I felt no more numbness.
Your helmet might be too heavy and place strain on you cervical vertebrae....if that's the case, you hands will fersure get numb....try a carbon fiber helmet.
Too tight gloves will fersure make you exert extra grip force and cause your hands to tire quickly...so try to find gloves that are premoulded where they make a fist when removed.
Check your seating/bar position...if you are leaning forward and placing lots of weight on your palms, then you need taller bars and more pullback and/or a more forward seat bucket.
