Help installing new grips
Old 06-30-2008, 08:54 AM
85RoadsterXLS's Avatar
85RoadsterXLS
85RoadsterXLS is offline
Default Help installing new grips
I just bought a new set of grips. Left side is not a problem, but the trhottle side seems to be very tight going on the sleeve. Measuring it looks like the grip inner diameter is about a 1/16 of an inch smaller than the sleeve.&nbsp\\;They are for one inch bars, which is what I have. I remember as a kid using soap to get grips on bike handlebars! Any suggestions?&nbsp\\;&nbsp\\;
Old 06-30-2008, 09:12 AM
Elvis Nixon's Avatar
Elvis Nixon
Elvis Nixon is offline
Default RE: Help installing new grips
Don't use soap! If they are rubber grips use Aqua-net aerosol hair spray and let it dry overnight.
Old 06-30-2008, 09:26 AM
85RoadsterXLS
The inside is rubber. Out of curiosity, what is the problem with soap?
Old 06-30-2008, 09:35 AM
Elvis Nixon
The potential problem with soap is that any water or condensation that gets in there will obviously make the grip slip. The hairspray lubricates just as well as soap when wet and sticks very well when it dries.
Old 06-30-2008, 11:40 AM
WVHogRider's Avatar
WVHogRider
WVHogRider is offline
A couple months ago, I had to shave the plastic throttle sleeve down to get my new grips on.&nbsp\\;
&nbsp\\;
Oh, and +1 on the hairspray if the inside is rubber.&nbsp\\;
Old 06-30-2008, 12:39 PM
Azwethinkweiz's Avatar
Azwethinkweiz
Azwethinkweiz is offline
Definitely hairspray if its rubber, thats how I've always put grips on dirtbikes and bmx bikes.
Old 06-30-2008, 03:09 PM
Mister H's Avatar
Mister H
Mister H is offline
Any tips for getting the left grip off the stock bars?
Old 06-30-2008, 03:12 PM
mpaquette's Avatar
mpaquette
mpaquette is offline
I took a knife to the left grip and cut it off.&nbsp\\; Wasn't planning to save it.
Old 06-30-2008, 03:18 PM
Mister H's Avatar
Mister H
Mister H is offline
I need to save mine for teh new bars...
Old 06-30-2008, 03:39 PM
Elvis Nixon
ORIGINAL: Mister H
After you have taken all the controls off the bars, use the smallest flatblade screwdriver you can find and gently slide it as far under the grip as you can. Take some WD-40 and slide the straw in next to the screwdriver and squirt. Repeat the pcocess in a couple areas of the grip and twist the grip back and forth and after a fight it should come off. Don't forget to clean the WD-40 off before you re-install them....
Quick Reply: Help installing new grips
