Problem with Sporty Saddlebag latches
I just picked up a 2006 XL883R with a pair of 53050-04B latching saddlebags. \\;\\\\\\; The bags lock and latch fine but the outside ring around the latches is cracked on both bags. \\;\\\\\\; The bike only has 2100 miles on it but I guess the bags could be older.
Anyway, does anyone know if the latches or just the outer dress rings can be purchased and replaced?
Thanks, \\;\\\\\\; Tad
I was researching this same problem and dredged up this post, so thought I'd reply with info I found:
The outside ring (Bezel) was superseded with the same part # but adding an "A" at end.
It could be and this is just a guess the newer part is better?
According to this 53050-04B Instruction Sheet:
https://www.shop.harley-davidson-ros.../53050-04B.pdf
Bezel, right 53126-04A
Bezel, left 53131-04A
I ordered them from zanottis, and will post if they fit/work any better...
