Miles On A Tank
06-19-2008, 05:27 PM
Miles On A Tank
i have an 05 1200C. i believe its 4.X gal tank. about how many miles do you guys go before filling up? ive been filling up every 120ish miles to be safe. but know i can go longer, just how much longer?
06-19-2008, 05:54 PM
RE: Miles On A Tank
150-160 highway miles
06-19-2008, 05:56 PM
RE: Miles On A Tank
Unless you modified it, you have a reserve of .5-.7 gal depending on how full you fill your tank.
Make sure your petcock os set to \\;ON &\\; run until your engine quits, then switch to RES - you should be able to go 20+ miles to get to a station.
I usually fill at 150 mi, and hit res at 150-160 mi
06-19-2008, 06:01 PM
RE: Miles On A Tank
The 4.5 gallon tanks on 883 and 1200 Customs have a 1 gallon reserve. I could go to about 170 miles before hitting reserve on my 883C I had.
06-19-2008, 06:47 PM
RE: Miles On A Tank
I have a 2008 883L, and I usually fill up after 110 miles, and put 2 gals in. So at that rate the whole tank should last ~165 miles
This is all on back roads, never higher than 4th gear/45 mph.
06-19-2008, 06:48 PM
RE: Miles On A Tank
thanks guys i appreciate it!
06-19-2008, 06:49 PM
RE: Miles On A Tank
I usually hit reserve about 170-175 miles. \\;
dstonemega
07-29-2012 08:12 PM
intense883
05-29-2012 09:09 AM
ish6323
06-17-2008 03:58 PM
dr.phatkins
03-26-2007 06:42 PM
spottedfool
08-19-2006 03:28 AM
