08 Nightster Exhaust
RE: 08 Nightster Exhaust
Yeah, most of the difference in your fuel mixture comes from a free flowing intake allowing more air into the engine. \\; Just an exhaust change you still have the restriction in the intake to slow the air down. \\; Since you're doing both you're going to want to do some sort of ECU change. \\; Depending on what intake you go with, you might be able to get away with the dealership ECU download (~$150) but you'd be much better off with something better. \\; You have a handful of options, but the most common seem to be the Fuelpak, PCIII (AKA Powercommander), and SERT (Screaming Eagle Race Tuner). \\; You'll never get everybody to agree on any one option, so ask around and see what works best for you. \\; The PCIII you can plug your laptop into and is highly tweakable, the Fuelpak is more simplified. \\; Some dig the simplicity of the Fuelpak, others dig the full tunability of the PCIII. \\; I don't know enough about the SERT to comment. \\; All 3 seem to be great products, you probably can't go wrong either way. \\; I have the PCIII, and I can tell you the driveability is WAY better. \\; No more surging at low speed part throttle, doesn't die when warming up anymore, throttle response is better, overall very happy. \\; The other good tuners probably have the same effect though.
